I’m in Pittsburgh and mostly tinker with Hiwonder kits in my spare time, working through voice and vision experiments on the development side. While reading around online, I came across this article about Apple reportedly aiming for an agentlike Siri as soon as next year, and it made me think about how people here structure their own voice-driven robot projects on Hiwonder hardware. The article link is third-party: Apple eyes agentlike Siri as soon as next year. My concern is practical, not about the Apple product itself. If agent-style assistants become the norm, I wonder whether Hiwonder users would keep building intent handling and command routing themselves, or lean more on external assistants and just pass results back to the controller. I don’t have a clear answer, since I’m still early in learning this. For those of you running voice or AI-agent style projects on Hiwonder platforms, which approach has held up better for you, and what would you watch out for?
Good question !!
Self-built intent handling / command routing (keyword spotting + simple state machine, or local speech-to-intent with something like Vosk / Whisper + custom logic) tends to hold up better when you care about:
- Low latency and predictable response
- Offline or unreliable network operation
- Tight control over robot behavior (especially safety-related commands)
- Learning the full pipeline yourself
Many people start here with the WonderEcho module or a USB mic + Python on the Pi/Jetson. It’s straightforward for fixed command sets (“walk forward”, “pick up the red object”, etc.) and stays reliable.
External agent-style assistants (ChatGPT, Claude, local LLMs, etc.) work better when you want open-ended conversation, multi-step reasoning, or flexible natural language. The usual pattern is: speech-to-text → send text to the LLM → parse the response (or use function calling) → translate the result into robot commands. This is flexible, but you have to watch out for:
- Latency (especially over the internet)
- Reliability (API downtime, rate limits, unexpected outputs)
- Cost if you use paid APIs heavily
- The need for a solid “command validation” layer so the robot doesn’t do something unsafe or nonsensical
- Keeping critical control loops on the robot itself rather than in the cloud
A hybrid approach is what a lot of people end up with: use the external assistant for understanding complex requests and generating plans, then pass only structured, validated commands back to the robot’s local controller. Local voice still handles emergency stop / basic motion.
Since you’re still early, I’d suggest starting with the local / self-built side so you understand the full loop, then adding an external agent later once the basic voice-to-action path is solid. That way the robot remains usable even if the agent is slow or unavailable.
Btw which Hiwonder robot are you using ?
