- Choose ESP32 S3-Cam if you want to quickly add basic vision recognition to small robots or robotic arms while prioritizing compact size, low cost, and simple integration.
- Choose ESP32-S3 if you want better structural protection and wireless communication. It adds a protective case and optimized antenna on top of the ESP32 S3-Cam, offering good value and easier project integration.
- Choose ESP32 P4C5-Cam for high-performance AI vision development. Its dual-chip architecture balances computing power and communication for complex AI vision scenarios.
- Choose WonderMV K210 if you want to go deeper into AI vision development through Python programming, source code modification, and model deployment.
- Choose WonderCam K210 (Little Bear) for AI vision beginners and K-12 teaching. It includes a visual interface and more than 10 built-in vision functions, allowing quick setup via preset features and IIC communication.
- Choose WonderMK K230 for advanced AI vision, multimodal AI interaction, and intelligent application development. Its screen comes with more than 30 preset vision functions and supports complex model deployment and robot interaction.
Product Overview
Hiwonder offers six vision modules—ESP32 S3-Cam, ESP32-S3, ESP32 P4C5-Cam, WonderCam K210 (Little Bear), WonderMV K210, and WonderMK K230—covering the full range from basic vision access and AI vision learning to advanced multimodal AI application development.
1. ESP32 S3-Cam: Compact Vision Module
Positioning: Provides a low-cost, lightweight basic vision solution for small device integration.
Hardware: Dimensions of only 27 × 42 × 19 mm. Based on the ESP32-S3 chip (up to 600 MIPS) with a dual-core 32-bit processor up to 240 MHz. Includes a 2-megapixel camera, external antenna, Type-C, and IIC interface.
Vision functions: Wi-Fi real-time video streaming (AP + STA), cat/dog detection, person recognition, face detection, color recognition, and QR code recognition.
Core advantages: Extremely compact size makes it suitable for space-constrained small robots, robotic arms, and embedded devices. Offers a lightweight vision solution for makers and beginners.
2. ESP32-S3: Cost-Effective AI Vision Module
Positioning: Provides a well-structured, stable-communication vision solution for robot vision integration and embedded device development.
Hardware: Based on the ESP32-S3 chip (up to 600 MIPS) with a dual-core Xtensa 32-bit LX7 processor up to 240 MHz and a 2-megapixel camera. Includes Type-C, IIC interface, programmable custom buttons, a protective case, and an optimized external independent antenna.
Core advantages: Improved structural design with protective case and external antenna enhances installation reliability and Wi-Fi performance. Better suited for robot vision interaction and embedded project integration.
3. ESP32 P4C5-Cam: High-Performance AI Vision Module
Positioning: Designed for high-performance embedded AI vision development, balancing on-device computing power and data transmission stability.
Hardware: Dual-chip architecture with ESP32-P4 (computing, up to 400 MHz) and ESP32-C5 (communication, dual-band Wi-Fi 6). Includes a 2-megapixel camera, external antenna, Type-C, IIC interface, and programmable custom buttons.
Vision functions: Wi-Fi real-time video streaming (AP + STA), color recognition, face detection, cat/dog detection, gesture recognition, face recognition, human skeleton recognition, pedestrian detection, QR code recognition, and YOLOv11n object detection.
Core advantages: Dual chips handle computing and communication separately for stable performance in complex scenarios. Rich AI vision features support diverse embedded AI vision applications.
4. WonderMV K210: Open-Source Programmable Vision Module
Positioning: Aimed at intermediate AI vision learning, Python programming, and vision application development.
Hardware: Based on the Kendryte K210 chip (up to 1 TOPS) with a dual-core 64-bit RISC-V processor up to 400 MHz. Integrates KPU, FPU, FFT, and other hardware acceleration units. Includes a 2-megapixel camera, 2.0-inch touchscreen, metal case, fill lights, TF card slot, Type-C, UART, and IIC interfaces.
Vision functions: Supports more than 10 functions including color recognition, visual line following, face detection, face feature detection, mask recognition, face recognition, QR code recognition, barcode recognition, AprilTag recognition, handwritten digit recognition, and object recognition with self-learning classification.
Core advantages: Improved chip performance for efficient AI vision inference. All vision programs are written in MicroPython and fully open source. Users can experience AI vision applications and modify or debug code to understand the underlying logic for greater secondary development freedom.
5. WonderCam K210 (Little Bear): Easy-to-Use AI Vision Module
Positioning: Designed for zero-foundation users with a visual operation interface and convenient AI vision interaction.
Hardware: Available with or without a metal case. Based on the Kendryte K210 AI chip (up to 1 TOPS) with a dual-core 64-bit RISC-V processor up to 400 MHz. Includes a 2-megapixel camera, 2.0-inch IPS display, five onboard fill lights, and IIC interface. Compatible with LEGO mounting holes.
Vision functions: Built-in more than 10 functions including color recognition, visual line following, face recognition, object recognition, image classification, feature learning, road sign recognition, digit recognition, tag recognition, QR code recognition, and barcode recognition.
Core advantages: Visual interface that works immediately after power-on. More than 10 preset vision functions allow quick robot vision applications without complex programming. Also supports custom model training for personalized projects.
6. WonderMK K230: High-Compute Multimodal AI Vision Module
Positioning: Aimed at advanced AI vision, multimodal AI interaction, and intelligent application development.
Hardware: Based on the Kendryte K230 chip (up to 6 TOPS, 13.7 times the performance of K210). Includes a 2-megapixel camera, 1 GB LPDDR4 memory, 2.4-inch capacitive touchscreen, microphone, speaker, multiple expansion interfaces, and Wi-Fi support.
Vision functions: Built-in more than 30 functions including color recognition, code recognition, face recognition, human feature recognition, and YOLOv8n & YOLOv11n model detection.
Core advantages: Stronger vision computing and model inference capability for more complex AI vision tasks. Integrates multimodal AI large models that combine voice, text, and image understanding for more natural intelligent interaction. Suitable for robot vision development, maker projects, and competitions.
Key Differences
Computing Chips
Chip architecture and computing power determine data processing capability, AI model inference ability, and application ceiling.
ESP32-S3 uses a dual-core Xtensa LX7 processor with up to 600 MIPS. It targets lightweight embedded vision processing for basic image capture and simple vision tasks.
ESP32-P4C5 uses a dual-chip design. The P4 provides strong on-device computing for complex vision algorithms, while the C5 handles high-speed networking for stable data transmission, offering a higher-performance embedded AI vision solution.
K210 uses a dual-core RISC-V architecture with integrated KPU, FPU, and FFT hardware acceleration units. It has dedicated AI inference capability for efficient lightweight neural network models.
K230 uses the next-generation Kendryte K230 AI chip with up to 6 TOPS, further improving model inference capability for more complex AI models.
Quick Application vs. Open-Source Development
WonderCam K210 (Little Bear) emphasizes quick experience with many built-in AI vision functions that require no complex programming. WonderMV K210 and WonderMK K230 support MicroPython and open-source code, allowing users to modify and debug programs for deeper learning of vision algorithm usage, model deployment, and custom applications.
Vision Functions and Application Capability
ESP32-S3 series mainly supports basic functions such as Wi-Fi video streaming, face recognition, face detection, and color recognition for simple vision perception.
ESP32 P4C5-Cam leverages its dual-chip design to support richer AI vision features including human skeleton recognition, QR code recognition, and YOLOv11n object detection.
K210 series includes built-in AI vision algorithms supporting more than 10 applications such as face recognition, object detection, image classification, and feature learning.
K230 further expands vision capability with more than 30 preset functions, supporting object detection, human detection, gesture recognition, and more. Combined with multimodal AI, it enables vision, voice, and text fusion applications.
Core Parameter Comparison
| Dimension | ESP32 S3-Cam | ESP32-S3 | ESP32 P4C5-Cam | WonderMV K210 | WonderCam K210 (Little Bear) | WonderMK K230 |
| Dimensions | 27×42×19 mm | 59×43×17.5 mm | 27×42×19 mm | 58.9×40.7×16.2 mm | 52×50 mm | 74×19×49 mm |
| Chip | ESP32-S3 | ESP32-S3 | ESP32-P4C5 | K210 | K210 | K230 |
| AI Compute | 600 MIPS | 600 MIPS | — | 1 TOPS | 1 TOPS | 6 TOPS |
| Camera | 2 MP | 2 MP | 2 MP | 2 MP | 2 MP | 2 MP |
| Field of View | 123° | 123° | 123° | 123° | 123° | 80° (expandable with rotating pan-tilt, 0–270°) |
| Display | None | None | None | 2-inch touchscreen | 2-inch display (no touch) | 2.4-inch touchscreen |
| AI Vision Functions | Cat/dog, person, face, color, QR code | Cat/dog, person, face, color, QR code | Human skeleton, QR code, YOLOv11n, 10+ functions | Face recognition, object detection, image classification, 10+ functions | Color, face, object recognition, 10+ preset functions | Object detection, human detection, gesture recognition, 30+ preset functions |
| Wi-Fi Video Streaming | Supported | Supported | Supported | — | — | Supported |
| AI Large Model | — | — | — | — | — | Supported |
| Development Environment | ESP-IDF, Arduino IDE | ESP-IDF, Arduino IDE | ESP-IDF, Arduino IDE | CanMV IDE | — | CanMV IDE |
| Core Advantage | Ultra-compact size, low-cost basic vision | Better structure, stable wireless communication for project integration | Dual-chip architecture for computing and communication | Open-source programming for AI vision algorithm learning | Easy to use, quick AI vision experience | High compute power, multimodal AI vision, and intelligent interaction |
Q1: Which module is recommended for zero-foundation AI vision learning?
If you want to quickly implement common applications such as color, face, and digit recognition, choose WonderCam K210 (Little Bear). Its visual interface allows quick AI vision applications without programming, making it suitable for classroom experiments and robot interaction. If you want to learn Python programming and vision algorithms further, choose WonderMV K210 or WonderMK K230.
Q2: How should I choose among the three ESP32 vision modules? Are the differences large?
In short, P4C5-Cam is the dual-chip solution that balances computing power and communication with richer AI vision features, suitable for high-performance needs. S3-Cam is compact and cost-effective. The S3 module optimizes the antenna for more stable data transmission and includes a case for easier installation and integration.
Q3: Do the six vision modules support different controller platforms?
They are largely the same. All six support STM32, ESP32, Arduino, Raspberry Pi, 51 microcontroller, and Jetson platforms. WonderCam K210 (Little Bear) additionally supports micro:bit and includes LEGO-compatible mounting holes for education and maker projects.
Q4: Does WonderMK K230 support offline vision? Does it require a cloud connection?
The module comes with more than 30 preset vision functions that can run locally. Cloud connection is only needed for its multimodal AI large model services, such as language models and related voice, text, and image understanding capabilities.
Q5: Which module is better if I want to recognize custom objects?
WonderCam K210 (Little Bear) or WonderMK K230 are recommended. You can collect image data for custom model training (local or online), then import the model file into the module for object recognition. Higher chip performance results in faster processing.
Q6: Which module should I choose to learn YOLO object detection?
WonderMK K230 is more suitable. It supports YOLOv8n and YOLOv11n object detection and can run more complex vision algorithm tasks. In the CanMV development environment, it is also more convenient for model calling, algorithm validation, and vision application development.
Q7: What is the difference between 600 MIPS and 6 TOPS?
MIPS mainly measures general CPU processing capability, suitable for program execution and data processing. TOPS measures AI inference capability, suitable for running neural network models. Simply put, the ESP32-S3’s 600 MIPS is better for basic vision processing and device control, while the K230’s 6 TOPS AI compute power is better for complex AI model inference and multimodal intelligent applications.
