MentorPi T1 Advanced – MS200 connects but does not produce LaserScan / blocking_test fails
  • Product model: Hiwonder MentorPi T1 Advanced – Tank version
  • SKU or kit name: MentorPi T1 Advanced (Depth Camera / Aurora version)
  • Purchase channel: [add purchase channel here: Hiwonder website / Amazon / AliExpress / other]
  • Controller board: Raspberry Pi 5
  • Operating system: Ubuntu 22.04 LTS + ROS 2 Humble
  • Connection method: Raspberry Pi accessed through VNC; MentorPi ROS environment running inside the official Docker container
  • Software version: Hiwonder Tool V2.0.1
  • Firmware version: Unknown
  • Image version: V2.0.1 – 2026-08-22
  • Tutorial step: LiDAR functions / Avoid Obstacle / MS200 LiDAR ROS 2 operation
I expected the MS200 LiDAR supplied with the MentorPi T1 Advanced to publish valid sensor_msgs/LaserScan data and allow the official “Avoid obstacle” function to work.
The Hiwonder Tool is configured as:
LIDAR: MS200
CAMERA: aurora
MACHINE: MentorPi_Tank
ROS_DOMAIN_ID: 0
VERSION: V2.0.1 | 2026-08-22
  1. What actually happened?
The LiDAR powers on and rotates normally, but no usable LaserScan data is produced.
The device is detected as:
/dev/ttyUSB0
and:
/dev/ldlidar -> ttyUSB0
The serial port operates at:
230400 baud
The LiDAR is definitely sending raw serial data. I can read several kilobytes directly from /dev/ttyUSB0.
The ROS topic /scan_raw exists and shows the MS200 node as a publisher:
Type: sensor_msgs/msg/LaserScan
Publisher count: 1
Node name: MS200
However:
ros2 topic hz /scan_raw
does not receive any messages, and:
ros2 topic echo /scan_raw --once
waits indefinitely.
The official “Avoid obstacle” function can be enabled in WonderPi, but the robot does not perform the expected LiDAR-based obstacle avoidance behavior.
  1. Error message or logs:
The official Oradar driver connects successfully:
get lidar type: MS200
get serial port: /dev/ldlidar, baudrate: 230400
lidar device connect success.
get lidar scan data
but no LaserScan messages are published.
I also tested the Oradar SDK directly, without ROS, using the included blocking_test executable.
It successfully reports:
scan_frame_data lidar device connect success..
but then continuously reports:
error: fail get full scan data
This is important because the failure also occurs directly in the supplied Oradar SDK, without ROS.
  1. Configure the robot using the official Hiwonder Tool as:
LIDAR: MS200
CAMERA: aurora
  1. Start the official ROS system and check:
ros2 topic info /scan_raw -v
The MS200 node appears as a publisher.
Then run:
No scan frequency is reported.
  1. Stop the ROS stack and run the included Oradar SDK test:
/home/ubuntu/third_party_ros2/third_party_ws/build/oradar_lidar/blocking_test
Result:
  1. Photos or short video:
I can provide photos of the LiDAR and a video showing that it powers on and rotates normally.
The identification label on the LiDAR appears to be:
A32608150823/11010V11
I would particularly like Hiwonder to confirm what the V11 designation means and whether it identifies a particular hardware or firmware revision.
I also noticed during assembly that the physical LiDAR mounting arrangement did not exactly match the unit shown in the assembly instructions. I had to rotate the LiDAR to align the mounting holes correctly.
  1. Wiring photo:
I can provide a clear photo of the LiDAR connection and mounting if required.
  1. Screenshot:
I will attach:
  • Hiwonder Tool showing Lidar: MS200
  • blocking_test showing lidar device connect success followed by repeated error: fail get full scan data
  • Photo of the LiDAR identification label
  1. I have already verified the following:
    • LiDAR powers on and rotates normally.
    • /dev/ldlidar correctly points to /dev/ttyUSB0.
    • Serial communication is at 230400 baud.
    • Raw serial data is actually being transmitted by the LiDAR.
    • The official Oradar driver successfully opens the device.
    • /scan_raw exists and has the MS200 node registered as publisher.
    • No LaserScan messages are produced.
    • The issue persists when using the Oradar SDK blocking_test directly, without ROS.
    • I have not modified the original LiDAR driver source code.
Could Hiwonder please confirm:
  1. What exact MS200 hardware/firmware revision corresponds to the label A32608150823/11010V11?
  2. Whether this LiDAR requires a different or newer Oradar driver/SDK.
  3. Whether there is a newer MentorPi T1 system image compatible with this exact LiDAR revision.
  4. If so, could you provide the official download links for the correct image, driver, SDK and firmware?
  5. If the LiDAR supplied with my kit is not compatible with the software included with the MentorPi T1, should the LiDAR be replaced?
  • Is this for a class, competition, or deadline?
No. This is a personal robotics development project, but the robot is new and the LiDAR is an original component supplied with the MentorPi T1 kit. I would prefer to use an official Hiwonder solution rather than manually patching the supplied driver.
We’re bringing in official support staff to help with your question. If you still need my assistance, you can @ me in this topic. @Hiwonder_Scarlett
Hi there,
Thank you for providing such a detailed problem description. Based on these details, it is very likely that the LiDAR type in the robot settings is not configured correctly. We would like to ask you to first confirm your LiDAR type.
If it is the LiDAR shown in this picture, please select sclidar for the LiDAR type field in the Hiwonder Tool, then click Save, Apply, and Quit to save the settings, and try again to see if the LiDAR-related applications can run normally.
Setting Steps:
(1) Start the robot and connect it to the VNC. For detailed steps on setting up the connection, please refer to 2.1 VNC Installation and Connection.
(2) In the remote desktop, double-click the robot system configuration tool. Then, click the Execute button to launch it.
Choose sclidar, then click Save, Apply, and Quit to save the settings.
We look forward to your reply.
