Hello Hiwonder Support Team,
My team is using the LeArm for our senior design project at UT Austin, but the arm is not responding to software commands.
Our controller board appears to be an older version than the one shown in your online tutorials, with a Micro-USB port instead of USB-C and one button instead of three.
We are unsure whether this is a software compatibility issue or if our computer is not recognizing the board. Could you provide the appropriate software, drivers, documentation, and any recommended troubleshooting steps for this older board?
Thank you! And have a good upcoming Thanksgiving!
Hi! For the Micro-USB LeArm controller, start with the 2024 LeArm 3-in-1 Windows PC software rather than the newer USB-C tutorial. The quickest way to narrow this down is to check whether Windows sees the board before opening the LeArm software.
- Power the arm and connect it. Plug in the arm’s power adapter, turn the arm on, and connect the board directly to the PC with a Micro-USB data cable. USB alone can trigger the arm’s low-voltage alarm.
- Check for a COM port. In Windows Device Manager, look under Ports (COM & LPT) for the CH340 entry that appears when you plug in the board and disappears when you unplug it. If it doesn’t appear, install
ch341ser.exe from the 2024 package under 7.附录 → 4.编程软件安装包汇总, then reconnect. If it’s still missing, try another USB port and a known-good Micro-USB data cable.
- Open the legacy app at 9600 baud. The app and its setup guide (
上位机软件介绍) are both under 3.机械臂动作编辑教学 → 1.上位机软件介绍 in the 2024 package. Select the COM port you saw in Device Manager, set 9600 (not 115200), and click Open Serial Port (打开串口). The indicator should turn from red to green. Keep the arm’s workspace clear and try a small movement with one servo slider.
You don’t need to press the board’s button to connect the PC app. The 2024 offline-operation guide uses that button to run a saved action group without the PC.
