JetMax——Pre-purchase questions: ROS 2 AI Robotic Arm (documentation, power, gripper, reach)
  • Product model: JetMax
Hello Hiwonder Support,
I am a robotics teacher planning to buy the JetMax ROS 2 AI Robotic Arm
for a student project:
We will mount the arm on a mobile robot frame (not a desk), run it from a
battery, and use it to pick up small objects such as empty cans from the
ground. Before ordering, I need to confirm the points below. Could you
answer them by number?
Documentation and software
1. Is there online documentation for this new ROS 2 version? The wiki I
found (wiki.hiwonder.com/projects/JetMax) covers only the older Jetson
Nano / ROS 1 version. Please send the link, or the manual as a file.
2. Which ROS 2 distribution and Ubuntu version does it ship with?
3. Is there a Python API to move the arm by coordinates (like
set_position(x, y, z) in the old version)? Is the source code provided
with the kit?
Power
4. What is the allowed input voltage range of the control board?
5. Can it run from a 3S lithium battery (11.1 V nominal, 12.6 V full)
instead of the 12 V 5 A adapter? Do you sell or recommend a battery?
6. What are the size and polarity of the DC power jack?
7. Is the Jetson powered through the same board, or does it need a
separate supply?
Gripper and reach
8. What is the maximum opening width of the gripper, in mm? We need to
grasp a standard beverage can (66 mm diameter).
9. Which end tools are included in each kit (gripper, suction cup)?
10. How far below the mounting surface of the base can the end tool
reach, in mm? Please also share the full working range (X, Y, Z).
11. What is the maximum payload?
Kit contents and mounting
12. Which kit includes the Jetson Orin Nano Super 8GB and the depth
camera? Where is the depth camera mounted (on the arm end or fixed)?
13. Could you share the base mounting hole pattern (hole spacing and
screw size) and the total weight of the arm?
Thank you for your help.
