Bus Servo Controller——Technical Feasibility
  • Product model: Bus Servo Controller
Can this driver (Bus Servo Controller) function as an expansion board to operate 18 servos simultaneously on a 6-legged robot?
Yes. The Hiwonder Bus Servo Controller can serve as a UART expansion board to coordinate 18 compatible serial bus servos on a hexapod. It does not drive standard PWM servos.
Assign each servo a unique ID before daisy-chaining them. Your main controller can then send one CMD_SERVO_MOVE command at 9600 baud with all 18 IDs, an individual target position for each servo, and a shared move duration.
Before moving all 18 under load, verify that the supply voltage is within the ratings of both the controller and the servos, and that the power supply, board, connectors, and wiring can handle the combined peak current.
References: Bus Servo Controller Communication Protocol (CMD_SERVO_MOVE) and Bus Servo Controller User Manual (sections 1.2–1.3).
