Ainova robot - Fan module doesn't work
:light_bulb: Using this template is recommended — you may also edit it freely, but you must fully describe your product and the problem (at least: product name, version, and problem description).
  • Product model: Hiwonder Ainova Pro
  • SKU or kit name: RM-HIWO-03F
  • Purchase channel: RobotShop
  • Controller board: AiNova CoreX controller board ESP32-based
  • Operating system: Windows
  • Connection method: USB
  • Software version: WonderCode V2.2.8
  • Firmware version: 1.15.0, Build: V1.15-57-g8a325e526
  • Image version: unknown
  • Tutorial step: unkown
  1. The fan won’t move. Instead of troubleshooting the whole code with the facial recognition, I have tried to just get the fan to work. There is power to the fan.
  2. There are no errors.
  1. Tried the AI Fan.sb3 downloaded from Hiwonder.
  2. I also tried to just start the fan with the attached fan startup code.png below.
  3. I also tried the default Fan module (Black) with the code, but it appears I have the IIC Fan module (see attached photos (5. WonderCode Fan options.png), (6. fan1.jpg) and (7. Ainova fan with power.jpg.))
7.
8. Since the IIC fan doesn’t have the option to use port 6, I tried it with the one available - port 3. See photo (9. Ainova wiring - fan to port 3.jpg). I tried just running the fan with the code fan startup code.png. The fan won’t spin.
9.
Additional Notes:
  • Looking at the photos of my fan, which WonderCode fan extension and Python library are compatible with the fan supplied in my AiNova kit?
    Can you provide me the code to just make the fan run? Once I have it running, I can then try the facial recognition part of the code.
Official support staff are being brought in to help with your fan module issue. If you still need the assistant’s help, you can @ me in this topic. @Hiwonder_Scarlett
Hi, there,
Thank you for providing the detailed information.
You can try the attached fan forward and reverse program file to see if it operates normally.
Fan Program: coreX.sb3 (50.3 KB)
During testing, please ensure that no other sensor modules are connected. We look forward to your reply.
Steps are as follows:
  1. Power it using two 3.7V 1200mAh lithium batteries. Connect the fan module to port 6 of the CoreX controller.
  2. Connect the CoreX development board to your computer via a USB cable. Open WonderCode and import the code file. Make sure to select the correct port.
  3. Click the upload button to upload the program.
  4. After the code is successfully uploaded, observe the status of the fan module.
Thank you for your response.
Here’s what I tried:
  • I disconnected all other sensors.
  • I downloaded the code, connected the fan to port 6.
  • Connected the corex board to the computer via USB.
  • Uploaded the program successfully through WonderCode.
  • Nothing happened with the fan (no movement, no light on the fan sensor)
  • Removed the usb connection an turned on the corex (realizing after the power isn’t connected…nothing happened)
  • I tried loading the program again using the same steps above, but now it times out at 5%
  • I tried connecting to the corex to the Hiwonder Python editor to see if I could get that to work - copy/paste the wondercode python code to the editor, tried Download and run. Still nothing happened
    . No light on the fan sensor or fan movement. See attached results.
  • Please see attached photo (only the fan sensor is plugged into port 6, corex usb to computer connection
Thank you again.
Hi, there,
Thank you for your message.
Could you please try re-flashing the firmware for CoreX first, and then re-uploading your program to see if it works properly? Here is the link to the course, which includes the firmware, flashing tools, and tutorials: [CoreX Firmware Flashing Tool & Usage Instructions]
Thank you for your reply. The Readme is a bit different than what I’m seeing. When I run the flash_download_tools_v3.6.5.exe, I select the ESP32 Download Tool and I see this:
Unlike the Readme, I have only one path above. COM5 is the correct port.
I’ll be honest, I have no idea what this really is…please verify this is what I should run.
Thank you.
Hi there,
Thank you for the information you provided. You can refer to this picture to set up the flashing tool, and please make sure to select the correct COM port (as you mentioned, COM5) and baud rate. Here is the firmware:
CoreX_v2.4.0_0x1000.bin (1.6 MB)
If you are still unable to flash successfully, we would appreciate it if you could record a video of the flashing process. Our engineers will review the video to diagnose the issue and provide you with a solution. You can upload the video to Google Drive and send it to us via a shareable link.
Here are the settings I used to flash:
It appeared to be successful. I have uploaded the video to Google Drive and shared with support@hiwonder.com. If that’s not correct, please let me know.
I uploaded the fan code and it was successful. Nothing happened. Fan did not move. No light on fan sensor.
Thanks again.
While the flash appeared to be successful, I’m still unable to get the fan to work. Any further suggestions on where to go from here? I confirmed the model of fan I have should work with the robot.
