A lack of knob response alone does not confirm that the expansion board is broken. The uHand UNO starts in neutral-position mode, which disables both knob and APP control until you exit it.
Please try the startup check in the official 4.1 Knob Operation tutorial:
- Set both the battery-box switch and the expansion-board switch to ON. The expansion board’s RGB light should turn white, and the hand should move to its neutral position.
- Press and hold K1 and K2 together. Release them when the RGB light turns green. This enables knob control.
- Wait two seconds, then turn each knob individually. S1–S5 control the thumb through the little finger; S6 controls the rotating base.
If it still does not respond, please tell us:
- Whether the RGB light comes on, and its color before and after holding K1 and K2.
- Whether the hand moves to neutral when switched on.
- Whether all six knobs fail or only particular ones.
- Whether you have uploaded a different program to the UNO.
Please also share clear photos of the expansion board and its connections. These observations will help narrow down the issue before concluding that the board needs hardware inspection.
