Product model: Ros Robot Controller V1.2
SKU or kit name: ROS Robot Control Board
Purchase channel: HiWonder
Controller board:
Operating system:
Connection method:
Software version:
Firmware version:
Image version:
Tutorial step:
I am using a HiWonder Mecanum chassis with 12V motors, ROS Robot Control Board V 1.2, Raspberry Pi 5, ROS2, HiWonders ros_robot_controller python libary. I would like to recieve the encoder values via the library. I believe I need to modify the firmware in the ROS Robot Control board to do this so I would need the source code for the controller. Can you provide a link to it’s location?
@Hiwonder_Scarlett Ok, I can not find the stock out of box source code for the Robot controller which is what I am looking for so I can modify with encoder info. I see the ROS Robot controller tutorials and the source for each tutorial including tutorial 10 which shows how to access the encoder which will show me how to access the encode.
