How to connect the hiwonder encoder motor module v 1.4 to pi 5
How long till a support staff can help?
@hiwonder_Ryo How long till a support staff can help?
I couldn’t find reliable material for this yet, so I’ve asked our support staff (Hiwonder_Scarlett) to follow up. Please watch this topic for their reply; support works on weekdays during Beijing business hours, so replies outside those hours may take longer. If you need me again, mention @hiwonder_Ryo.
Hi there,
Thank you for your patience.
Here is the wiring diagram for SDA-IO2 and SCL-IO3:
Regarding the power supply, it depends on the working voltage of your motors. If your motors operate at 12V, this battery will work as long as it can output 12V. The working voltage of the 4-channel motor driver board is DC 3V–12V.
This tutorial can be used to drive 520-model motors with the Raspberry Pi. You can check the documentation path: Raspberry Pi Development Tutorials
Can I know the power supply type being used here please? And can It power the motors and pi?
@hiwonder_Ryo
The power source in the photo cannot be identified reliably because its voltage and current labels are not readable. I would not connect it until those specifications are confirmed.
For your specific chassis:
  • Motors: The listed motors are rated at 8 V, and the chassis working voltage is 6–8 V. Use a regulated DC supply set to a suitable voltage in that range, connected to the motor module’s marked + and − power input.
  • Current: The motor specification you provided does not state rated or stall current. Therefore, the required supply current cannot be confirmed from the available information. It must be sufficient for all four motors, including startup/stall demand.
  • Raspberry Pi 5: Use a separate USB-C supply confirmed for the Pi 5. Do not power the Pi from the motor module’s I²C 5V pin; that pin is input-only. On V1.4, the serial connector’s former 5V pin is NC.
  • Communication: Keep the Pi and module connected with a common GND, plus SDA and SCL. The module guide supports independent supplies for the controller and motor module.
Your 11.1 V nominal / 12.6 V fully charged battery must not be connected directly to this 8 V motor module setup. Your 5 V USB-C converter may be used only for the Pi branch if its manufacturer confirms Pi 5 suitability; it is not a motor supply. For confirmation of the pictured supply, please provide a close-up of its voltage, current, and output-type label.
Hello @Hiwonder_Scarlett ,
In the picture I noticed a black board on top of the Pi 5. Is there a way to connect the motors to the Pi 5 without that board because I already have a camera attached to my Pi and the black board would block it.
Absolutely. The expansion board essentially just breaks out the Pi’s GPIO pins. You can simply run jumper wires from the I2C pins on the 4-channel motor driver directly to the corresponding I2C pins on your Pi 5.
@Hiwonder_Scarlett So just to confirm
I need to connect my Pi 5 to the Hiwonder board’s I2C port using three female-to-female jumper wires to SDA (Pin 3), SCL (Pin 5), and GND (Pin 6), and leave the 5V pin empty to not short circut the Pi.
Also for my battery setup (picture below) I realized that the wire connecting to the encoder board of the motors is to thin and will probably melt as the current flows so is it better if I get another Parallel XT60 Y-Splitter Cable (1 Female to 2 Male, 14AWG) and a pack of standard XT60 Male connectors with heat-shrink tubing? Because in my current set up I think I messed up and did it in a way that my battery is plugged into one leg instead of the main trunk, and Pi’s buck converter is plugged into the other leg, and the main trunk of the splitter is forced to go up to my motor board. So will the right way be the Pi’s buck converter and the motor board connect are on the 2 legs and the battery is connected to the main trunk? Also, is the current buck converter on the Pi correct for the conversion of power since I don’t want to accidentally fry my board. Also if I do end up getting another Parallel XT60 Y-Splitter Cable and connect everything correctly is it enough to just cut the thin wires very short (like under one inch) so that they don’t melt?
This is the thin wires I’m referring to (the white connect at the top connects to the encoder module board of the motors to provide power)
Hi,
Thank you for your message.
Regarding your question about the wiring setup, yes, the correct setup is to have the Pi’s buck converter and the motor expansion board connected to the two branch legs, while the battery connects to the main trunk.
As for the buck converter, yes, the voltage conversion is correct as long as it steps the power down to 5V. Before using it, you can use a multimeter to measure and verify the output.
Also, when connecting wires, try to use wires of the same type and gauge. Connecting different types of wires with dissimilar copper strands can cause them to overheat and potentially melt over extended periods of use.
If you have any further questions, please feel free to reach out.
@Hiwonder_Scarlett Hi,
For the wiring (and to prevent melting) do you recommend using a crimping tool or cutting the thin red and black wires on my white plug until they are less than half an inch long and interlock the thin copper strands with my 14 AWG wire strands and put solder in it until it forms a solid bond and then cover it with heat-shrink tubing?
Hi there,
Both of the methods you mentioned are feasible.
@Hiwonder_Scarlett Hello,
I just want to confirm that using the below battery:
is ok for the motors because the 11.1V battery can output up to 12.6V when fully charged and I think the motors are rated for 8V; is there a chance of it overvolting the motors?
Hi there,
There is an issue: under long-term or slightly heavy loads, it is extremely prone to rapid overheating due to excessive current and high rotational speed, which will significantly shorten its lifespan or even burn it out.
I will be using it for max 15 min before letting it cool. Is that fine or is there another way to prevent it from melting? Also will the below wires overheat because those were the only wires i found with the specific white connector at the end to connect to the encoder module.
@Hiwonder_Scarlett
Your approach can only be used during the testing phase, but it must never be used as a long-term solution. If the wire stays at a normal temperature within 15 minutes, that means there is enough margin; if it feels hot to the touch, then it is no longer suitable for this application, and you should immediately switch to another method—separate power supply is the safest approach.
