Comprehensive Analysis and Selection Guide for Three Common Communication Protocols Including I2C, UART, and SPI
1. Introduction
Data communication serves as the core link connecting hardware modules such as sensors, actuators, and storage chips to controllers, including microcontrollers, Raspberry Pi boards, and other processing units within embedded systems, IoT devices, and industrial control fields. I2C, serial communication including UART, RS232, and RS485, and SPI represent the three most widely used short-distance serial communication protocols today. Significant differences exist among these three protocols regarding pin design, communication mechanisms, speed performance, and applicable scenarios. This guide systematically analyzes the distinctions across four dimensions, including protocol principles, core characteristics, comparative differences, and selection recommendations to provide a technical reference for choosing communication solutions in embedded development.
2. Core Principles and Characteristics of the Three Protocols
Communication ProtocolI2C
Dual-wire Multi-Controller Multi-Peripheral Bus
Serial Communication UART
Asynchronous Point-to-Point or Multi-Node Communication
SPI
High-Speed Synchronous Full-Duplex Controller-Peripheral Interface
Pin ConfigurationSDA and SCL
Both lines use open-drain outputs and require external pull-up resistors typically between 1 kΩ and 10 kΩ to ensure stable operation.
TX and RX
Communication requires a cross-connection where the controller TX connects to the peripheral RX and the controller RX connects to the peripheral TX.
SCLK handles the serial clock, MOSI handles the controller-out peripheral-in line, MISO handles the controller-in peripheral-out line, and CS functions as the chip select signal. Note that the CS pin can be omitted in simplified scenarios involving a single peripheral device.
Communication MechanismThe bus accommodates multiple controller devices, such as two microcontrollers along with multiple peripheral devices. Peripheral devices are distinguished by unique 7-bit or 10-bit addresses, and the controller selects the target device by transmitting an address frame. If multiple controllers contend for the bus simultaneously, an integrated bus arbitration mechanism prevents data collisions.Asynchronous communication operates without a clock line. Data is transmitted in frames where each frame consists of a 1-bit start bit featuring a low electrical level to signal the frame beginning, 8-bit data bits for the core payload, an optional 1-bit parity bit for error detection, and 1 or 2 stop bits featuring a high electrical level to signal the frame end. Controller and peripheral devices must use the same predefined baud rate to synchronize sampling timing.Once the controller device selects a peripheral device, a fixed-frequency SCLK clock is generated, and data is synchronized on specific edges of the SCLK line. The controller device transmits data bit by bit over the MOSI line according to a predefined bit order and the peripheral device samples on the same edge. Simultaneously, the peripheral device returns data bit by bit through the MISO line, which the controller device samples on the same edge. Upon completion of the data transfer, the controller device drives the CS pin of that peripheral device high to release it back to an unselected state.
AdvantagesMinimal pin count saves PCB space. Support for multi-controller and multi-peripheral topologies offers flexible deployment options. The architecture requires no chip select signals, simplifying hardware design.Low pin count. Operating without a clock line simplifies hardware design. RS485 extension supports long-distance and multi-node deployment with high interference resistance. Frame formats can be fully customized.The transmission speed is extremely high, outperforming I2C and serial communication. Synchronous communication ensures strong data stability. Full-duplex transmission allows simultaneous data transmission and reception. Independent CS pins eliminate address conflicts, providing better interference resistance than I2C.
DisadvantagesTransmission speeds are relatively low and fall far behind SPI. Open-drain outputs limit the total bus loading capacity to a maximum of 10 to 12 devices. Interference resistance is weak because dual-wire transmission is highly susceptible to electromagnetic interference, making it unsuitable for long distances.The transmission speed is moderate with a maximum UART speed of approximately 10 Mbps, which is much lower than SPI. Standard UART only supports point-to-point communication, while multi-node setups rely on RS485 extension. The absence of a hardware addressing mechanism requires software protocols such as custom device addresses, for multi-node communication.Higher pin count requiring 4 lines, which exceeds I2C and standard serial configurations. Only a single-controller multi-peripheral architecture is supported, lacking multi-controller capability. Multiple peripheral devices require additional dedicated CS pins, increasing PCB routing complexity. The lack of a hardware error detection mechanism necessitates software-implemented verification.
3. Core Differences Analysis
3.1 Synchronization Mode: The Fundamental Distinction Between Asynchronous and Synchronous
Serial communication is the only asynchronous protocol because it operates without a clock line and relies on the baud rate for synchronization. While this simplifies hardware layout, the transmission speed is limited because baud rate deviations can easily cause data errors. Conversely, I2C and SPI are synchronous protocols that rely on controller-generated clock lines, specifically SCL and SCLK, to achieve synchronization. This results in higher speeds and superior stability at the expense of requiring an extra clock pin.
3.2 Topology Flexibility: The Trade-off Between Multi-Controller and Multi-Peripheral
I2C stands out as the only protocol supporting multi-controller multi-peripheral configurations. This is ideal for scenarios where multiple main controllers, such as two microcontrollers, share multiple peripherals, though the bus arbitration mechanism introduces additional software complexity. SPI supports only a single-controller multi-peripheral structure and lacks multi-controller capability, but it completely avoids address conflicts through individual CS pin gating. Standard serial communication is strictly point-to-point, requiring RS485 extension for multi-node networks along with software-based address management.
3.3 Speed and Stability: SPI as the Primary Choice for High-Speed Scenarios
In terms of data rates, SPI reaches tens of Mbps, outperforming serial communication at up to 10 Mbps and I2C at a maximum of 3.4 Mbps. For large data payloads such as LCD screen updates and SD card read-write operations, SPI serves as the primary viable option. I2C and serial communication are better suited for low-throughput applications, including sensor data acquisition and command transmission.
3.4 Interference Resistance: Prioritizing RS485 for Industrial Environments
For interference resistance, differential-signal RS485 ranks highest, followed by synchronous SPI, open-drain I2C, and finally single-ended standard UART. Industrial environments and long-distance deployments exceeding 10 meters should prioritize RS485. For short-distance chip-to-chip communication under 1 meter, either I2C or SPI can be selected.
4. Selection Guidelines for Application Scenarios
Protocol selection must balance four core requirements: transmission rate, distance, device count, and hardware cost. The following sections outline specific scenario-based selection guidelines.
4.1 Scenarios Favoring I2C
  • Short-distance, multi-device, low-throughput environments: Examples include communication between a microcontroller and multiple sensors such as the SHT30 temperature and humidity sensor or the BH1750 light sensor, AT24C02 EEPROM chips, and DS3231 real-time clocks.
  • Restricted PCB space: Requiring only two lines, this setup suits pin-constrained, compact devices such as smart bands and miniature sensor nodes.
  • Multi-controller shared buses: This applies to configurations where two microcontrollers share a single EEPROM, requiring collaborative operations across multiple controller devices.
Typical Case: Networking an Arduino with three SHT30 temperature and humidity sensors, where the sensors are differentiated via 7-bit addresses without requiring extra chip select pins.
4.2 Scenarios Favoring Serial Communication UART or RS485
  • Short-range debugging and straightforward communication: This includes debugging links between a computer and a microcontroller using a USB-to-serial adapter, or positioning data transfers between a microcontroller and a NEO-6M GPS module at a baud rate of 9600 bps with low data volume.
  • Long-distance, multi-node industrial deployments: For communication between a PLC and a sensor located 100 meters away on a factory floor, such as a pressure sensor, RS485 is highly preferred due to its superior noise immunity and extended range.
  • Low-cost, low-complexity requirements: This option eliminates the need for complex synchronization or address management when simply transmitting point-to-point commands, such as a microcontroller driving a relay module.
Typical Case: A Raspberry Pi communicating with five workshop temperature and humidity sensors via an RS485 module across a transmission distance of 50 meters, with multiple nodes differentiated through software-defined addresses.
4.3 Scenarios Favoring SPI
  • High-speed, large-volume data transmission: Examples include image data transfers between a microcontroller and an LCD screen like the ST7735, which requires transmitting hundreds of thousands of pixels per second, or high-speed data storage during SD card read and write operations.
  • Full-duplex simultaneous transmission and reception: This is necessary for links between a microcontroller and a wireless module like the nRF24L01, where control commands must be sent while simultaneously receiving wireless data.
  • Short-distance scenarios with strict noise immunity standards: A prime example is the communication link between a drone flight controller and its electronic speed controllers, where high speed and absolute stability prevent packet loss that could lead to a loss of control.
Typical Case: An STM32 microcontroller controlling an SD card via SPI to achieve file read and write speeds exceeding 10 MB per second, a performance level far outstripping I2C and standard serial connections.
